I varied from the plans and did not final rivet the forward fuse assembly before attaching the fiberglass cabin top. Not really an issue because it's very easy to remove and reinstall the fuse top with the cabin top in place. However, as a result of installing the upper switch block and A pillar conduits, I left a smaller opening for the center steel post at the center top of the cabin top. The issue became installing the steel center post after the fuse top is installed. I ended up extending the slot in the fuse top forward a couple of inches. That required some modification to the internal support structure to accomodate the extended opening. None of this work was difficult and now the steel bar slips into place easily. The extended slot will be covered by the leather glare shield.
