Sanded the A pillar/upper switch box again. After it was all dry I mixed body filler and applied a thin coat to the face of the switch box in order to level off the fiberglass cover. After the filler dried I sanded it down with 220 wet then applied a coat of primer to visualize the surface condition. The surface has some imprefections/pin holes that will requires some more work. I also need to do a bit more contouring along the front. But for the most part, it is looking good.
I then started making poster board templates for the aft headliners. I got the right side done.
