The joy of fiberglass. Today I sanded...again...the interior cabin cover. It's looking much better. I wet sanded so am waiting for everything to dry out before I proceed. The front A pillar area still needs some micro skim coat to further level out the finish. I also need to do some touching up of the area just aft of the door openings. Otherwise, everything is looking much better and should be ready for the first primer coat. But that only means more sanding. Speaking of sanding, I did sand the center throttle quadrant console. This piece is ready for priming.
