Continued to work on various fuselage tasks. Installed one fresh air inlet hose. Began fabricating a fiberglass inlet Y. Installed the overhead switch panel. Installed and glued in place two conduits that will run down the A pillar of the fiberglass cabin cover. Cleaned up various aluminum fuselage parts. Installed the Andair fuel selector valve extension, top plate and selector handle.
