Installed the flap control motor and exterior flap horns. A bit of a challenge accessing the four attach bolts for the horns. My arms are a little beat up but the horns are on nice and tight.
Began installation of under floor electrical conduit. I purchased some one inch corregated plastic conduit similar to the smaller conduit Van's sells. I installed four straights runs from behind the baggage compartment to the front of the rear spar bulkhead. This conduit material is a bith thinner and not as rigid as Van's but should be fine. I also plan to run some conduit along the sidewalls.
