Rick's Web Site
Date:  11-17-2019
Number of Hours:  4.30
Manual Reference:  39-6 through 8
Brief Description:  Paint and Control Systems
Painted the front seat pans and structure below which will remain visible after interior installation.
Continued work on the control systems. Fabricated and installed the idler arm. Attached the forward and mid elevator control arms. Fit, drilled and installed the contol column, control stick base and control sticks. It looks like I'm going to have to deal with interference of the fuel line attached to the fuel control valve due to the new style boost pump. As I noted a week or so ago the new pump supplied by Vans required locating the fuel filter further aft. The issue that I believe this change created is to also push back the fuel line that decends from the fuel valve to the filter appears to interfere with the movement of the control arm. I'll know for sure after I finish installing the control arm.
