Brief Description: Rudder Cables and Elevator Controls
Fabricated the forward rudder cable links. Due to the nature of the Control Approach pedals, I will need to order a few longer AN 23 clevis bolts. The control arms of the new style Control Approach pedals will cause the links to bind unless they are mounted on the outside of the arms. The fix is not a significant issue, it just requires a longer clevis.
Began installation of the two forward elevator push pull tubes. Also began fabrication, cleaning, deburring and priming of the elevator idler arm assembly.
