Rick's Web Site
Date:  11-7-2019
Number of Hours:  3.20
Manual Reference:  36-3, 37-2/3, 38-4
Brief Description:  Brake & Fuel System, Rudder Pedals
Installed the parking brake to rear tunnel brake lines. I still don't have the parking brake but will finish up the lines once it's mounted.
Fabricated and installed the fuel lines fromt he selector to tunnel bulkhead fitting and then from the tunnel to the fuselage exit. Also mounted the 45 degree firewall fuel fitting.
Began work on the rudder pedals. I have the Control Approach pedals. Began assembly of the outboard mounting blocks.
