Rick's Web Site
Date:  11-5-2019
Manual Reference:  36-2 & 3
Brief Description:  Prime & Brake Lines
Primed a boatload of interior parts.
Began installation of fuselage brake lines. I've purchased the Bonaco stainless steel lines and had to figure out how they are incorporated into the system. It seemed I didn't have all the lines. Consequently, I called Bonaco and had a nice discussion which cleared things up. I didn't realize that their kit does not include lines from the firewall to the exit at the gear leg bracket. They stated that too much flexible hose line will cause a loss in pressure and result in mushy brakes. They recommended using hard aluminum line, per plans, for those runs. So, I began installation of the hard aluminum lines from the gear leg bracket to the tunnel and from the tunnel to the parking brake.
