Rick's Web Site
Date:  9-29-2013
Number of Hours:  4.10
Manual Reference:  11-6 & 7, 12-3
Brief Description:  Mount Empennage & Install Push-Pull Tube
Finished mounting the empennage. Corrected the mounting hole in the elevator's control horn attaching the push-pull tube. Mounted a 1/4" Heim bearing which allowed correction of the elevator alignment.
Finished mounting and adjusting the elevator push-pull tube.
Trimmed the horizontal stabilizer fiberglass tip. Cut and glued the foal closeout for the tips.
Push-pull bellcrank
Push-pull bellcrank
Push-pull tube
Push-pull tube
Elevator control horns and push-pull tube
