Brief Description: Mount Empennage & Install Push-Pull Tube
Finished mounting the empennage. Corrected the mounting hole in the elevator's control horn attaching the push-pull tube. Mounted a 1/4" Heim bearing which allowed correction of the elevator alignment.
Finished mounting and adjusting the elevator push-pull tube.
Trimmed the horizontal stabilizer fiberglass tip. Cut and glued the foal closeout for the tips.
