Worked on the right side of the panel. Wired the overhead dimmers. Ran the ground runs for the pilot and copilot sticks. The copilot sick will have a switch on the ground line to disable the entire stick's functions if necessary. Secured the wires along the fuse side and overhead. Installed the right panel and determined the O2 sensor inteferes with the right fuse block tray. I ended up relocating the CD fuse block and the far right Skybolt fastener. It's still a tight fit but everything works. I can see the light at the end of the elecrical tunnel.
