Finished the trimming of the baggage upper bulkhead cover. Added a bit of foam along the panel/upper console interface for a bit tighter transition. Leather and embroidered "Experimental" will finish off the cover. Aerosport will finish the work along with the seats hopefully, in the not too distant future.
Test fit the right forward side panel just to visualize how it interfaces with the exposed windscreen plexi. There is a bit of panel that extends above the aluminum windscreen and can be viewed from outside the plexi. Will need to consider when we lay out the fiberglass windscreen fairing.
