Worked on the installation of the pitot regulator and the magnetometer. Both devices will be mounted in the wings. Easily mounted the pitot heat reguator to the access door adjacent the pitot mast. The magnetometer will also be installed on a wing access hatch. Had to fabricate a mount that will allow adjustments in pitch and yaw. Determined after the first attempt that the mount interferes with the the aileron push/pull tube. Modifications tomorrow.
