Removed the left pant after applying the flox mixture to the four inboard mounting points. I sanded the excess flox down smooth then applied a thin cabo mixture and one layer of cloth to the mounting points. I reinstalled the pants and attached the brackets with wing nut clecos. I also applied a flox mixture to the axle extension to produce a solid mounting point. I also went back and made some adjustments to the right pant. I'm going to redrill the attach points tomorrow.
