Rick's Web Site
Date:  9-27-2020
Number of Hours:  1.70
Brief Description:  VOR Antenna Cable
I began running the VOR antenna cable. I ran it from the antenna along the bottom J channel. I then transitioned up one bulkhead and further ran it along with the static line to the baggage bulkhead. My body is a bit sore and stiff from working in the tailcone. The run to the front should prove a bit easier. But can't complain too much, the -8 is a lot tougher dive to the rear fuse.
