Mounted the ELT antenna below the empenage fairing....or at least where it will be.
Also reran the static line to proceed up the left side of the fuse. Just a minor adjustment since the ADHRS will be on the left side of the panel.
Lastly drilled out the mounting and conductor holes for the VOR antenna. I'll wait to rivet the nutplates to the fuse when I get an extra set of hands.
