After grinding down the outside edge of the right door flange to reestablish the correct seal gap, I needed to smooth out the filler previous applied to the remainder of the outside flange. That's quite a sentence. Anyway, I began the slow process of smoothing things out. The battery powered disc sander appears to be a good start. The wet sanding and likely further filling will come later
