I filled the few edge voids along the insterts of the instrument panel. I used a bunch of flat toothpicks to carefully apply the filler. After I sanded the filler I spot primed. I then finished sanded the interior of the cabin top along with the remaining carbon parts with 400 wet. It's been very windy the last few days. If it calms down tomorrow, I think I'll take the cabin top out onto the driveway and start sanding the outside gelcoating. I'm considering priming the outside before the final assembly. I realize there will be more filling after attaching to the fuselage but it will be easier to sand and prepare much of the top while off the fuselage.
The engine mount is finally on its way and should arrive on Wednesday.
