Rick's Web Site
Date:  6-6-2020
Number of Hours:  2.60
Manual Reference:  FF1-2
Brief Description:  Assembly and Modify Oil Cooler Mount
Due to the air conditioning it was decided to use a larger oil cooler. So, like anything, one change leads to another. This is actually a very easy modification to the oil cooler mount. I removed the upper flange which bolts the oil cooler with three nutplates. I then fabricated a new flange with extruded angle, Everything is drilled to size and the six nut plates are in place. I primed the new attach angle. It's nice to avoid fiberglass for a bit.
