I fit, trimmed and glued the fiberglass cover to the front of the overhead switch plate. After the Cabo dried, I further sanded it level. Tomorrow, I'll apply a coat of polyester filler before the final sanding prior to primer.
I also received the firewall forward kit today. I'll be able to start some firewall tasks but it sure would be nice if Van's would send the firewall which, by the way, has been on backorder from February. I realize the pandemic has created some issues but this critical part has been on order months before the outbreak. Thankfully, there's always other work to do but this is getting a bit silly.
I had to trim away a bit of the inside of the switch console in order to access the support bar nuts.
