Still working on the installation of the ADSB for the RV-8. I did attach the right door gas strut attach brackets. After their installation, I wasn't happy with the alignment of the PlaneAround fuse gas strut attach bracket. The bracket was tilted a bit too much and caused the strut to bind. The PlaneAround bracket is tighter around the gas strut eye and consequently has a tighter tollerance than Van's original bracket. I mounted the strut to both brackets and applied more flox between the fuse top and attach bracket. I tightened the three attach screws and adjusted the bracket until the alignment was correct. The flox will fill the adjusted angle and provide a solid mounting pad when dry.
