I sanded the micro skim coat on the exterior of the right door opening. I then mounted the right door. Instead of following the instruction's process for locating the fuselage engagment holes for the fore and aft door pins, I followed Mark C's recommendation and simply found the hole centers by measuring the location of the pins on the door and transferring the center point to the fuselage. This technique worked out perfectly. Afterwards, I mounted the front pin guide to the fuselage.
