I measured the 1/4" gap around the right door opening to accomodate the McMaster-Carr door seal. Trimming will be in a day or two...joy.
I test installed the hinge caps for the doors. These were fabricated by my good friend Bob. They are a modified design from the caps available on-line. They use the countersunk screws which then allows for the caps to be a thinner profile. I need to do a bit more work to get a good fit but I'm exceptionally happy with the way they turned out.
