I removed the cabin side door strut attach bracket from the flox platform. I then sanded to final shape and cleaned up the platform. I also countersunk the screw holes for the bracket. Everything came out well. I fabricated a bracket locating bar from a wooden paint stirring stick. The Van's attach brackets for the door extend a bit into the window opening. There is a fair amount of "meat" on the brackets which will allow for some trimming. I drill the brackets in place tomorrow and determine the amount of material that needs to be removed.
