Rick's Web Site
Date:  4-3-2020
Number of Hours:  1.10
Brief Description:  Assemble Doors
I removed the left door to inspect the results of the slurry fill along the door channel. The weatherstripping I used wasn't quite thick enough to provide a good surface along the entire perimeter. But the filler dried adequately and has a decent enough fill and shape. It will just reuquire a bit of sanding. I'll go with a bit thicker weatherstripping for the right door. The weatherstripping I did use however, is a perfect thickness to backfill the lip along the bottom edge of the cabin to door interface. So, using the weatherstripping, I applied a layer of Cab/micro slurry along the bottom of the cabin door interface.
