Rick's Web Site
Date:  3-28-2020
Number of Hours:  4.20
Manual Reference:  45-5 & 14
Brief Description:  Doors
As I mentioned yesterday, I was getting some grinding on the door handle operation from the Aerosport stainless steel mounting plate and the main gear collar. I tried a number of differnt things to solve the problem but nothing completely eliminated the interference. So, I went ahead and opened up the main mounting hole of the stainless steel mounting plate and now no more grinding.
I trimmed the left fore and aft door pins per the PlaneAround instructions. I remounted the door and marked the cabin top opening for the McMaster-Carr door seal. I also did a bit more gap trimming/sanding of the left door. I did a little more cleaning up of the right door. I'll finish up the trimming and fitting of the right door and then remove the cabin top and trim and sand the door openings. I'd prefer to do that work outdoors.
1/4" trim line mark
