As I wait for a refill of Cab-O-Sil I decided to jump back in time a bit. I wasn't particularly thrilled about the baggage door hinge. More specifically, I wanted a means of easily removing the door but unfortunately, if you build per plans, you're out of luck. I looked at a few ideas from other builders but didn't really see anything that I like. I ended up installing #4 nut plates on the fuse side of the hinge in lieu of pop rivets. It's a fair number of nut plates but would not a big deal and would make removal much easier and doesn't require modifying the hinge. So today, I installed the nut plates and countersunk the hinge to accomdate the #4 SS screws. The Cab-O-Sil showed up this afternoon, so back to doors tomorrow.
