I removed the left door from the fuselage. I used a bit of Vaseline on each cleco and as a result, their removal was easy. I cleaned up and redrilled the holes for the door latch system. I had to do a bit of sanding to get the exterior level for the door latch and handle. I also filled the cleco holes on the left cabin top. Lastly, I began assembly of the door hinges. It snowed all day today so I'll wait to trim the door. I'd prefer to tackle that task outdoors.
