Kept trimming and sanding the canopy cover. I further trimmed the rear edge that interfaces with the baggage bulkhead. In addition, I further trimmed down the lower door opening. I used a belt sander which made quick and accurate work of the trim. I reset the cover to check my work. I still have a bit more trimming to do on the left rear edge to clear the longeron. I also plan to make the initial cut around the door opening.
