1. Installed the front and rear tunnel cover attachment plate and nutplates. 2. Dimpled and installed the two wire cover plates. 3. Installed the lower bolt access plates. 4. Attached the parking brake bracket to the firewall. Installed the parking brake and AN tubing hardware. 5. Installed the master cylinder and resevoir AN hardware. 6. Installed the upper brake line hoses to the resevoir, master cylinders and parking brake. 7. Riveted the heater tee duct.
Parking brake bracket. A much less expensive option than the aftermarket bracket sold by Van's.
