Determined the location of the belly condenser scoop. Pilot drilled the front and rear center mounting holes. Marked the location of the scoop on the bottom of the fuselage to ensure no nutplate interference with fuselage structure.
Condenser Scoop
Initial Mounting. Fiberglass mounting flange will require a bit of work to sit flush.
