Brief Description: Assemble Forward and Mid Fuselage Assemblies
Back from the big show. Began assembly of the front and mid fuselage sections. I riveted the forward fuselage ribs to the forward main spar bulkhead. Made initial assembly of the two sections.
While I was gone, I received the inside heat duct flanges from Vans. I primed, drilled and riveted the inside flanges. The bolted the two heat valves to the firewall.
