Rick's Web Site
Date:  6-26-2019
Number of Hours:  4.80
Manual Reference:  27-4 through 6
Brief Description:  Assemble Forward Rib Subassemblies
Continued assembly of the forward rib subassembly. Finished riveting the nut plates. Riveted the nose gear tension fitting, vertical firewall supports and forward ribs. Also installed the rudder pedal brace. Filled the recess holes with proseal.
