Sanded the micro slurry off the left wingtip. The top and bottom of the wingtip are leveled out to the contour of the wing skins. I trimmed the piano hinge pins and marked the phenolic block for drilling.
I refit the right tip. The pins have been very tight. I relieved glass from the inside of the tip which has helped considerably. I probably still need to remove a bit more glass. I'll sand down the right tip tomorrow. Joy.
