Brief Description: Assemble Flaps and Aileron Push Rods
Removed the right flap trailing edge clecos and riveted the double countersunk rivets. Installed the remaining hardware on the right flap. Lastly, placed a drop of epoxy in the pulled rivet holes on the right flap bottom.
Installed the left flap trailing edge with Proseal and clecos.
Began fabrication of the aileron push rods. Drilled on the end caps and began priming.
