Numerous tasks today including installing the baggage bulkhead vertical support, stiffeners for bellcrank ribs, and rear fuselage deck. I installed the two main longerons and final drilled all the skin holes below the longerons. I installed the rear most upper bulkhead, upper three J-channel stiffeners and the two top skins. I drilled out the top three J-channel stiffeners.
Rear fuselage deck and preparing to install the main longerons
