Kept working on these pesky trim tabs. Dimpled and countersunk, as appropriate, all the trim tab pieces. Riveted the control horns, end ribs and bottom of the main spars. Primed all parts. Glued the foam ribs in place and put everything aside to dry. Cut the trim tab piano hinges to inital length and mounted to the elevators.
