Test installed the right tank fuel float sensor. I ordered some Torx head screws from MicroFasteners to install the sensor vice standard Phiilips head screws. I know form past experience taht if ever need to remove the sensor the Torx screws are far superior. I will use Torx in many applications throughout the airplane. I also installed the first four ribs on the left tank.
