Rick's Web Site
Date:  11-9-2013
Number of Hours:  4.10
Manual Reference:  14-4 through 6
Brief Description:  Install Ribs
Drilled couduit holes in the main wing ribs. My plan is to run two conduits per wing. One will run to the wing tip. The other will run to the bellcrank area for the pitot tube (which is a planned deviation), pitot heat and auto pilot.
Mounted wing ribs
Mounted wing ribs
Bolt and rivet attachment typical for each rib
