Rick's Web Site
RV-10
14-4 through 6
Install Ribs
Drilled couduit holes in the main wing ribs. My plan is to run two conduits per wing. One will run to the wing tip. The other will run to the bellcrank area for the pitot tube (which is a planned deviation), pitot heat and auto pilot.
Mounted wing ribs
Bolt and rivet attachment typical for each rib
RV-10 Home
3594
Air Conditioning
Cowl
Doors
90
231
279
171
762
Instrument Panel
Oxygen
Spinner
Wheel Pants
Windows
557
