Rick's Web Site
Date:  9-25-2013
Number of Hours:  1.30
Manual Reference:  11-7 & 12-3
Brief Description:  Mount Rudder and Empennage Tips
Mounted the rudder and verified proper deflection. The rudder tip is slightly higher thatn the vertical stabilizer tip. I put down a layer of micro on the vertical stab tip to match the rudder.
Began installation of the horizontal stabilizer tips. The tips appear t be poorly matched. I may be able to heat up the tips and make sufficient adjustments.
Rudder and vertical stab with slightly offset tips
Layer of micro
Layer of micro
Full empennage
Full empennage
