Sonex 1292
Date:  8-28-2009
Number of Hours:  15.00
Brief Description:  Naca Vents Polish fuselage
The last few days I spent putzing with parts that I didn't make before and need to use now. I also cut holes for the Naca vents. When I installed the brace for the rudder pedals I originally drilled the installation holes for it on the wrong side of the vertical brace - so I had holes in the wrong place, right where they can be easily seen. Fortunately, I was able to cut the hole for the Naca vent right where these holes where. Once I had both the holes cut, I wanted to polish the area around the holes so I wouldn't get black gunk all over the inside of the vent - but once I started polishing I didn't stop until I had 3/4 of the fuselage polished. Of course it is only the first couple of passes and I'll have to go over it again a few times with the finer polish, but it went pretty quick.
