Sonex 1292
Date:  8-24-2010
Number of Hours:  3.00
Brief Description:  Print review # 2
Tonight I continued to go through all the prints to see if I missed something or screwed something up. It’s a good thing I’m doing this because I found something that would be pretty important. When I made sure the elevator had the right amount of travel, I discovered that it did not travel up far enough. The major reason I found why the travel wasn’t enough was because the holes in the seat pan were not big enough. The sticks hit on the seat pan before full deflection was reached. Once I increased the size of the holes and made a few other slight adjustments with a file, the elevator would then reach full deflection.
