Sonex 1292
Date:  6-27-2009
Number of Hours:  5.00
Brief Description:  Rigged the flap and aileron to the wing
Rigged the flap and aileron to the wing. When I checked the travel the aileron would stick at the maximum travel limits sometimes. I couldn't get a file or any other tool in to remove a little material around the hole where the counterbalance goes, but I was able to get some sandpaper in there, so I was able to remove enough material so it doesn't stick anymore. After I thought about it, I probably didn't need to do anything, because I think there will be some mechanical stops built into the metal framing for the sticks, so the aileron would never get to the point where it stuck.
