Brief Description: Installed the Landing lights into the Right Wing
Cut the hole and installed the Duckworks landing light cover into the right wing. It seems to go pretty well, although I'm sure the lens isn't water tight - but then the 5000 rivets holes in the wing aren't water tight either.
Spent the afternoon getting the third stall of the garage ready so I can move up there. I was building in my shop, which is in my basement (heated), but now with the nice weather, I can go out to the garage to build the fuselage. Besides, if I built the fuselage in my basement shop, I'd have to tear apart the outside wall to get it out as it's much wider than my door.
