As i talked about yesterday, I made some shape blocks and 'indented' the bottom aft skin for the access cover and installed some nut plates which should be much nicer than simply using the sheet metal screws. Using the shape blocks to make the indent was really quite easy and worked pretty well - the only issue was that since the skin isn't perfectly flat at that point on the wing the cover itself has to have just a little curvature in it.
ALso, as can be seen by image #2 I installed the Aileron push rods prior to skinning - just seemed much easier doing it now rather than with the skins on.
