Sonex 1292
Date:  7-22-2010
Number of Hours:  3.00
Brief Description:  Installed pos/nav/strobe in right wing
Tonight I installed the Position/Navigation/Strobe light into the wing tip and installed the wing tip onto the wing. I’ve seen were some builders install the wing tips with screws so it can easily removed but I don’t see the need. When I installed the pos/Nav/Strobe lights I used T-nuts so I could RTV and screw the light to the wing tip, so I can pretty easily remove the light. With the light removed, I should be able to pull the wires out enough to access the connectors to the light, if necessary.
