Tonight I sanded the work I had done on the dog house so that it would fit the slide seal that pulls into position by a draw string. I then fit the canopy skirt in place and match drilled the holes the same way I did with the alum skirts. I used the home made hole finder. The fit now is really good. I think I might still lay up some glass to seal it even better. I read some where that all I will need to do is tape off the fuselage and lay some glass under the area that needs fitting then close the canopy on to the glass.
