Today was a slow day. Sherri has been home all weekend so I cleaned up the garage, drained the compressor and she did some more Holiday decorating. I also finished up the Canopy latch handles. After fitting the handle yesterday I lined up the handle then drilled through the handle and shaft with a #30 bit (It calls for a #29 but didn't have one) then opened the front hole and two shaft holes to #18. Then I tapped out the rear handle hole to 8-32.
